Activity Forums Apple Final Cut Pro Legacy spotlight effect
  • spotlight effect
    Posted by Paul Nevison on September 26, 2006 at 10:00 pm
    hey there
    I am wanting to create a spotlight effect that can move around the frame and make visible only that which is in the oval (similar to the opening of james bond films). i have tried using the oval shape and using a multiply composite mode but when i move the oval around the video underneath is exposed around the edges when i move the oval layer.
    is there a way to do this that has an X.Y position in the controls tab independent of the XY in the motion tab
    thanks for any suggestions
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.7
    QT 7.1.2
    FCP 5.1.1
    BMD Decklink Extreme 5.6.2
    PAL Land
    John Fishback replied 19 years, 11 months ago 3 Members · 4 Replies
  • Justin Luo
    September 27, 2006 at 2:24 am
    you might want to try the facelight plugin from https://www.haiku.com.au/
    tweaking the values on the tabs might help to to achieve your desired results.
    give it a go!
    Rgds,
  • Paul Nevison
    September 27, 2006 at 8:48 am
    great thanks
    i have that plugin already and have used it in another capacity ….i will give it a go thanks for the tip!
    4.0G RAM
    OS 10.4.7
    QT 7.1.2
    FCP 5.1.1
    PAL Land
  • Paul Nevison
    September 27, 2006 at 9:48 am
    unfortunately the facelight plugin didnt do the job as it only creates a highlight rather than a cutout to view the layer below. it does have the XY controls i was after however. I know this effect must be simple to achieve in FCP, my brain is in freeze mode!
    4.0G RAM
    OS 10.4.7
    QT 7.1.2
    FCP 5.1.1
    PAL Land
  • John Fishback
    September 27, 2006 at 7:53 pm
    I’ve seen a tutorial to do this. It was prbably here on the Cow. I don’t remember if it was using FCP or AE. Try searching the Cow tutorials.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
