Activity Forums Apple OS X spotlight and images
  • spotlight and images
    Posted by Michele Princigalli on April 28, 2005 at 6:18 am
    Tomorrow Tiger is coming out. Will it fix the OS X image viewing problem? There is no mention of it on the apple web site (as if viewing images was not important to many Apple users). I think I saw an animation about Spotlight, where after finding images it was possible to have a slideshow, in real time, without funny drag-and-drop, preview programs, and slow image viewing. There is some hope! I think it will still be inferior to Windows simple XP integrated image viewing, but at least one can gain a minimum of functionality.
    The question is, will we still need Iphoto then? If I can view photos faster in OSX, and can still assign keywords o files, baybe I can (finally) erase Iphpto 5 and all of its bugs!
    Michele Princigalli replied 21 years, 4 months ago 2 Members · 6 Replies
  • Mark Sloan
    April 29, 2005 at 10:56 pm
    From: https://arstechnica.com/reviews/os/macosx-10.4.ars/9
    “Some categories have more elaborate previews. For example, images can be displayed in a full-screen slide show. During the slide show, each image can be zoomed to fill the screen, or copied into the user’s iPhoto library with a single click (complete with a genie-like animation). There’s also a “contact sheet” effect that tiles all the images in a full-screen grid of thumbnails.”
  • Michele Princigalli
    April 30, 2005 at 5:19 am
    thanks, great and useful article! I’m glad someone understands my concern and replies to my constructive criticism without calling me traitor and accusing me of provoking 🙂
  • Mark Sloan
    April 30, 2005 at 5:45 pm
    Last I checked, XP didn’t support PSD files, so the Tiger solution should work even better.
    May 2, 2005 at 12:05 pm
    Yes, I noticed that Tiger supports PSD files very well. So between slideshow and Iphoto (properly configured) one has a very solid solution on Tiger. Iphoto on my Powerbook is now extremely fast even with thousands and thousands of high res images. The only thing I wish Apple did, is to let me erase photos from Slideshow. I think Apple thought of slideshow as a presentation featue, but it could be used for excellent browsing, because you can also put all the images side by side. Erasing and Rotate would make it perfect.
  • Mark Sloan
    May 2, 2005 at 2:25 pm
    when in slideshow mode, you can’t hit Apple-delete? i won’t be installing 10.4 for quite some time so i haven’t had the opportunity to try it out… And if it doesn’t, there is a section no the Apple website for suggestions.
    May 8, 2005 at 12:09 pm
    Yes I sent apple a note on the issue. There are actually two problems with using slideshow for that: you can’t delete pictures, and it shows a random order of pictures. Obviously the feature s only there for entertainment purposes. So for now, the only solution is to make sure IPhoto run as quick as possible, or use a Windows machine (or emulator) to view pictures, and OS X for everything else.
