Activity Forums Maxon Cinema 4D Spot Light. Point source radius
  • Spot Light. Point source radius
    Posted by Alex Reardon on December 1, 2016 at 7:42 pm
    Good Morning Hive.
    I’m a lighting designer working for touring acts. I use a lot of moving-head light fixtures whose beam exits the light fixture with the same radius as the lens.
    My problem is that the source of a c4d spot light is a point, not a user-definable radius. To date, I’ve been placing the spot light towards the back of the light and “fudging it” by adding a disk light to represent the lens. The beam is still narrower than the aperture. If I place the c4d spot behind the light, and exclude the light fixture in the object attribute manager, I get a volumetric cone sitting behind the light fixture.
    I was wondering if there was some way of being able to spread the start point of the spot light….
    Thoughts please?
    Thank you.
    -Alex-
    Alex Reardon replied 9 years, 9 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    December 1, 2016 at 11:08 pm
    I think you’re looking for the “near clip” parameter in the light’s Details tab.
  • Alex Reardon
    December 1, 2016 at 11:29 pm
    Ah HA!
    I had a feeling it would be something remarkably obvious.
    Thank you very much.
