Activity Forums Adobe After Effects spoon reflection
  • Darby Edelen
    June 7, 2007 at 9:43 pm
    Your solution will involve distorting the image, whether you use a simple Distort>Bulge effect or a Distort>Mesh Warp effect. I recommend the latter. Since a spoon is a relatively simple shape, you can probably get away with using only 2 rows and columns for the effect in order to keep it simple.
    Also you must consider the way a reflective surface alters the light hitting it, you will need to use blending modes to try and achieve this look and you might want to put some specular highlights above the reflection layer (they tend to obscure reflections).
    Those are my suggestions =)
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Richard Bachman
    June 8, 2007 at 11:08 am
    “There is no spoon”
  • Vampiremidget
    June 9, 2007 at 3:58 pm
    Thank you very much for your suggestions, the problem is that I have never used AE before and I’m only beginning to learn it.
