Activity Forums Sony Cameras Spontaneous White Balance shift SONY FS5
  • Spontaneous White Balance shift SONY FS5
    Posted by Don Wellman on August 4, 2023 at 1:46 pm
    I’ve been shooting live storytellers for 10 years – the last six with Sony FS5 – same settings, same lighting. Recently, my white balance goes “kablooey” without warning or any apparent change. Is there a secret setting that is causing this? (example, just a few frames apart)
    Rob Neidig replied 3 years, 1 month ago 2 Members · 1 Reply
  • Rob Neidig
    August 7, 2023 at 5:51 pm
    It would be helpful if you let us know what settings you are using. Are you possibly using the “Full Auto” mode? That could possibly shift the White Balance while recording. Otherwise if you’re using “Preset” or have manually white balanced for positions “A” or “B” then it shouldn’t shift on you.
    Rob
