Activity Forums Adobe After Effects Splitting Video Based on Content
  • Splitting Video Based on Content
    Posted by Adam Bloemink on October 30, 2009 at 5:00 pm
    Hey all,
    Does anyone know if there is a way to split up a captured video based on the content? (I.E. slate, 3 seconds of black, etc.)
    Basically, I have several large (2 hour) clips of music videos that I need to seperate and label. Splitting these up manually is going to be a huge pain and I’m looking for a way to streamline this process- each music video has a 2 second slate at the beginning.
    I’m familiar with the Magnum – Edit Detector script in After Effects, but it won’t fit my needs.
    Does anyone have any suggestions?
    Thanks a lot!
    Adam Bloemink
    https://www.lucrativestudios.com
    Adam Bloemink replied 16 years, 10 months ago 2 Members · 4 Replies
  • Joey Burnham
    October 30, 2009 at 5:51 pm
    AE is definitely not the right tool for this. Just bring the material into your NLE of choice. I would think the material isn’t just randomly placed about so it shouldn’t take that long.
    Joey
  • Adam Bloemink
    October 30, 2009 at 6:01 pm
    Actually, it is fairly randomly placed. The songs range from 2-5 minutes long, so there’s no easy way to just slice them up.
    I’m working with 80 two-hour videos too, totaling around 2200 songs. NLE is my last resort.
    You’re probably right that AE is the wrong program, I just figured that there may be a script or something available.
    Perhaps this question would be best suited for another section unless anyone else has suggestions.
    Adam
  • Adam Bloemink
    October 30, 2009 at 7:10 pm
    Haha, ok.
    Thanks for the help anyways.
  • Adam Bloemink
    October 30, 2009 at 8:32 pm
    If anyone’s interested, here’s the work flow I’m using:
    1. Import all 80 clips into AE
    2. Split each music video manually (Edit > Split Layer, or Apple-Shift-D on Mac)
    3. Render layer script (https://www.redefinery.com/ae/view.php?item=rd_RenderLayers)
    It’s the easiest way I’ve found so far, this could be just because I’m more of a compositor than editor. There’s a fair bit of manually labour involved, but at least I don’t have to batch export out of an NLE which would add a lot more work.
    It also makes it very easy to demux all of these videos, as a nice bonus for the client would be to have audio-only versions.
    Thanks again,
    Adam
