Activity Forums Adobe Audition Splitting stereo signal to two mono tracks
  • Splitting stereo signal to two mono tracks
    Posted by Brandt Wilson on July 27, 2010 at 12:15 am
    I’m playing with stereo wav sound clips that originated from a pair of lav mics. I’d like to split this wav into two mono tracks. Can this be done in Audition either natively or with a plugin?
    Ideally, I’d be able to run a script that made the change and resaved the file without rendering, so that I could simply import it into Premiere for sync.
    Brad Dismukes replied 13 years, 2 months ago 4 Members · 3 Replies
  • Gerry Bayne
    July 27, 2010 at 6:32 pm
    Stereo tracks are split on the screen into top and bottom. Simply highlight the bottom track and then under the “File” menu, choose “Save Selection.” Then do the same thing to the top track. You will then have two saved mono tracks.
  • Eddie Tun
    January 22, 2013 at 3:32 am
    How can simply highlight the lower part of the stereo tracks. I try to highlight lower part but the upper part is coming along. Please
    Eddie
  • Brad Dismukes
    June 26, 2013 at 8:47 pm
    In the waveform tab to the far right of each track are very small L and R buttons. unchecking one will allow you to select the other, which you then need to save as a separate file etc.
    The soundtrack pro and FCP user in me is questioning the choice of NLE right about now.
