Activity Forums VEGAS Pro splitting captured avi file
  • splitting captured avi file
    Posted by Mel Perez on April 7, 2009 at 12:40 am
    Hi..i recently captured 90 minutes of footage for a community projectd in Vegas pro8. Files were saved as a 13gb & a 8gb avi file. I would like to split the avi files to give to someone to edit in Final Cut with his Mac.I assumed i could load the footage into Vegas, cut to smaller portions, and render out as an avi, and avoid recompression and quality loss. Was hoping to be able to fit files on a few dvd disks . I must be doing something wrong as the 8gb file i split in half renders out to 47gb, yes not 4.7gb, file size so no way i am gonna burn those to disk. Would anyone know what i am doing wrong or maybe a better way to handle this? Any help would be much appreciated…Thanks
    Terry Esslinger replied 17 years, 5 months ago 2 Members · 7 Replies
  • 7 Replies
  • Terry Esslinger
    April 7, 2009 at 2:08 am
    It sounds like you are burning it back to an uncompressed avi file rather than a DV avi file. Would be grossly larger.
  • Mel Perez
    April 7, 2009 at 5:00 am
    rendering to NTSC DVD seems to have taken care of at least the file size problem…thanks Terry, appreciate the help….
  • Terry Esslinger
    April 8, 2009 at 5:38 am
    That would probably render it as an MPEG2 which would make it a smaller file but would degrade the resolution.
  • Mel Perez
    April 8, 2009 at 8:31 am
    Hey Terry…am still a little confused. I selected the NTSC DV template because i didn’t see an DV option. Degrading the quality is not what i am after. Should i be using the “default template (uncompressed)” to produce exact copies of the regions i select? …Thanks again
  • Terry Esslinger
    April 8, 2009 at 5:32 pm
    I am going to assume that you are using SD and not HD.
    Use save as type : Video for windows (.avi)
    and template : NTSC DV
    It should use smart rendering and use no recompression and you should get the size files you are looking for.
  • Mel Perez
    April 8, 2009 at 9:13 pm
    Hey Terry…yes,i am working with sd. I meant to say i used the NTSC DV template the second time around, not NTSC DVD for those who may be wondering also. All is good now….Thanks
    Hey Terry…guess i am still a little confused.I selected NTSC DV because i didn’t see a DV option in the template drop down menu. So should i select the “default template (uncompressed)” to render an exact copy?…Thanks again
  • Terry Esslinger
    April 8, 2009 at 10:24 pm
    You want the NTSC DV for the exact copy. As that should be what you captured from your camera (unless you are in PAL land). Your camera does not produce uncompressed avi.
