Activity Forums Adobe Premiere Pro Splitting Audio Tracks
  • Splitting Audio Tracks
    Posted by Scott Lowe on May 8, 2009 at 6:42 pm
    I’ve got a project that I’ll need to be encoding for a 5.1 dts bluray and 5.1 dts dvd. I’m using Minnetonka’s dts encoder which imports all tracks separately from 6 separate mono .wav files (a .wav for the front left, another .wav for the front right, another .wav for the rear right, etc) and it won’t import a 5.1 wav.
    Is there any way to export separate mono tracks from a 5.1 mix in premiere?
    Thanks in advance for the help.
    Eddie Lotter replied 17 years, 4 months ago 2 Members · 1 Reply
  • Eddie Lotter
    May 9, 2009 at 4:10 pm
    [Scott Lowe] “Is there any way to export separate mono tracks from a 5.1 mix in premiere?”
    Not that I’m aware of. You will need something like Adobe Audition to take a 6 channel file and split it into 6 mono files.
    Cheers
    Eddie
