Splitting and merge together
Posted by Nico Stojanovski on April 18, 2009 at 9:01 pmHow do I make two scenes that have been splited, into one clip? So the get pasted together and act as one.
Rob Strobbe replied 17 years, 4 months ago 4 Members · 5 Replies -
Terry Esslinger
April 19, 2009 at 4:14 amOne way is to “group” the two pieces/
There are scripts that will rejoin Splits.
Nico Stojanovski
April 20, 2009 at 7:55 pmThat works fine for moving. But the splits are still visible, and can make trouble when fading the audio or the video as it still goes by where it was split.
Nico Stojanovski
April 20, 2009 at 8:18 pmAlso when adding Video FX it just adds to the already splitted part.
Mike Kujbida
April 21, 2009 at 12:46 amBut the splits are still visible, and can make trouble when fading the audio or the video as it still goes by where it was split.
Why would you fade the audio or video at the split?
Didn’t you join them so they’d be one clip?Also when adding Video FX it just adds to the already splitted part.
The only way to work around this is to render the two split segments together as a new file and bring it back into Vegas as one event instead of two.
Rob Strobbe
April 22, 2009 at 1:40 amCouple options:
1. Instead of trying to fade the event(s), use track-level envelopes. Composite Level envelope for video, volume envelope for audio. Also, apply FX to the track instead of to the event(s).
2. (Assuming you’re using a recent version of Vegas Pro.) Save this collection of split events to a VEG file and then bring that VEG into a new project. Vegas will treat this as an event that you can then move, fade, whatever.
Rob
