Activity Forums Adobe After Effects Spliting up layers in the timeline
  • Spliting up layers in the timeline
    Posted by Carl Fritzell on June 24, 2008 at 11:52 pm
    Hello all!
    I’m fairly new to AE and I have one small problem. I mainly use the program for editing undergroud music videos with alot of poor footage and fast cuts.
    As it is now, I do all the cuting Premiere and export a final cut to AE for placing of effects.
    This means I have one single video file that contains alot of different clips with different lightings for exemple.
    When doing color correction on there I am now forced to create a new layer for every cut thats made. Is there any way to have a specific layer be split up inside the time-line(Except for “Split Layer” of using Key Frames)?
    Regards
    Carl Fritzell
    Carl Fritzell replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jason Milligan
    June 25, 2008 at 1:00 am
    Why not use an adjustment layer?
    Add your effects to the adjustment layer and add keyframes (mostly hold keyframes) whenever you need to adjust your color settings.
  • Carl Fritzell
    June 25, 2008 at 9:39 am
    Hello!
    My apologiez for a fairly foggy explanation.
    Thats what I have done, using Adjustment Layer but I have had to
    create a new layer for every single cut that brings me to the specified footage.
    But thats the best way?
    Are there specific Key Frames for “Start” and “Stop”?
    Regards
    Carl Fritzell
