Activity Forums VEGAS Pro split track with “ignore event grouping” on
  • split track with “ignore event grouping” on
    Posted by Willie Bobo on September 2, 2015 at 5:06 pm
    Hi guys,
    I have 4 tracks with different video but exact same (music) audio track.
    I want to split/crop the vid tracks but leave the audio tracks alone (for visual reference) so I select “ignore event grouping” and hit “s” to split the vid track only but I get the red indication that it’s no longer aligned with it’s audio track (+ 2:25.38 every time no matter where in the clip I split it).
    It only happens in one of the tracks and it shows to be synced before splitting (no red warning unless I move the clip left or right so I assume it’s synced)
    I’ve never seen this happen before…any ideas?
    Thanks very much,
    Randy
    Willie Bobo replied 10 years, 12 months ago 2 Members · 2 Replies
  • Wayne Waag
    September 3, 2015 at 2:27 am
    I’m not sure exactly what your problem is or if you even have one. It seems that you have 4 video tracks and 1 audio track. (BTW, if you have 4 audio tracks that are the same, you can simply delete three of them.) You want to keep the audio track, but slice up the video tracks. If that’s the case, I don’t see that you have a problem. If you slice the video track that includes the one remaining audio track, then sure you will get out-of-sync indications. Even so, I don’t see a problem. Regardless, a screenshot of your timeline would be most helpful.
    wwaag
  • Willie Bobo
    September 3, 2015 at 4:38 pm
    Thanks, I realize I can delete the other audio tracks but like I mentioned I needed to save them for reference points to make sure I keep all 4 tracks synced throughout the editing process.
    Anyway, I can work around the issue, I’ve just never seen this happen and was just curious.
    Thanks again,
    Randy
