Activity › Forums › Avid Media Composer › Split track Quick Time
Posted by Dan Crouch on September 24, 2015 at 1:26 pmHi Guys,
Can anyone please tell me how rto make a split track QT in MC*?Ty
Dan Crouch replied 10 years, 11 months ago 3 Members · 3 Replies -
Shane Ross
September 24, 2015 at 3:53 pmhttps://forums.creativecow.net/thread/45/897962
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Richard Sanchez
September 24, 2015 at 5:30 pmEasiest way is to make sure you’ve mixdown your audio into the appropriate splits you want (or if you’re using mix stems lay them in the track configuration you need). Export a QT Reference (Make sure you select the audio mixdown). The Quicktime Reference will create a discrete channel for each track. After that you can safe a self contained Quicktime in Quicktime Pro 7 or if you need to compress it, you can run it through compressor.
Richard Sanchez
Los Angeles, CA“We are the facilitators of our own creative evolution.” – Bill Hicks
Dan Crouch
September 28, 2015 at 1:42 pmThanks for the post’s guys.
I did a mixdown in the end and it worked fine.Very much appreciated.
Dan.
