Activity Forums Apple Final Cut Pro Legacy Split Track Audio???
  • Split Track Audio???
    Posted by Peter on May 31, 2005 at 3:51 pm
    Hi there,
    What would the procedure be to capture a split track beta master, then output back out to a new split track beta master?
    FCP 4.5
    Decklink Extreme
    Sony UVW 1800
    Mackie 1402 VLZ Pro
    Thank you in advance!
    Tom Matthies replied 21 years, 3 months ago 3 Members · 3 Replies
  • Tom Matthies
    May 31, 2005 at 9:20 pm
    Bring in your footage with Log & Capture audio set to “Ch1 + Ch2”, edit to timeline as usual. Make sure you don’t pan your audio tracks to center. Leave them panned left & right. Output back to tape as usual.
    This is assuming that you can feed to split track from the Beta to whatever you use for input to your computer. You should be able to go right inyto your DeckLink card. If you go thru a mixer, make sure that your channels are discreet and not mixed together
    Tom
  • Rob Forsythe
    May 31, 2005 at 9:51 pm
    [Tom Matthies] “Bring in your footage with Log & Capture audio set to “Ch1 + Ch2″, edit to timeline as usual. Make sure you don’t pan your audio tracks to center. Leave them panned left & right. Output back to tape as usual.”
    Well, Tom, that’s ALMOST correct. 😉
    If you want to leave the audio SPLIT (without making further pan adjustments)
    you should set the Audio Capture to “Stereo”.
    That will capture the two audio tracks separately and “leave” them panned far Left and far Right (“split”) on the FCP timeline.
    If you set the Audio Capture to “Ch1 + Ch2” that will capture them separately but automatically pan both tracks full CENTER (mono).
    You’d NEED to manually pan them to Left & Right during the edit.
    A small but important distinction.
  • Tom Matthies
    June 1, 2005 at 3:03 am
    Oops! My bad.
    Tom
