Activity Forums Adobe Premiere Pro Split stereo audio tracks once in edited sequence
  • Split stereo audio tracks once in edited sequence
    Posted by Paolo Drusi on February 7, 2023 at 10:40 pm
    Is it possible to split stereo audio tracks once in edited sequence?
    How can I split a stereo audio track into 2 mono track from within a sequence?
    Thank you,
    Paolo
    Bill Celnick replied 3 years, 7 months ago 3 Members · 2 Replies
  • Ann Bens
    February 8, 2023 at 4:14 pm
    Not if the audio is already in the timeline.
    You modify the clip in the project window and insert it into the timeline.
  • Bill Celnick
    February 14, 2023 at 10:34 am
    You could export your audio to 2 wav files, checking off “export each channel as a separate file”
    Then create 2 mono tracks in your sequence and import the 2 files created above and place them there accordingly.
