Activity › Forums › Adobe After Effects › Split single clip into two using masking
  • Split single clip into two using masking
    Posted by Jared Snyder on February 21, 2014 at 7:53 am
    I have a sunrise clip. The sunrise is in real-time and quite slow, so I want to speed it up. However, if I just speed up the clip, the ocean tide will speed up too, which I don’t want to happen. What is the best way to go about splitting the clip into two separate pre-comps, so I can do a time compression on the sunrise without effecting the ocean tide? Thanks!
    Roland R. kahlenberg replied 12 years, 7 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    February 21, 2014 at 10:52 am
    Lots of options – masks, RotoBrush, keying, AutoTrace, mattes or a combination of the above. It all depends on the footage you’re dealing with.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
