Activity Forums Apple Final Cut Pro Legacy Split screening
  • Split screening
    Posted by Nathan Gadd on March 8, 2011 at 4:58 pm
    Hello, i am a fairly new user to Final Cut Pro, and am in the process of editing some footage from a student film to try and create an effect very similar to the split screens used in the TV series “24”. I am already familiar with how to split screen 2 different clips, but i cannot seem to work out how to add even more clips to the split and create it in a grid-like fashion.
    Any help would be greatly appreciated.
    Mark Suszko replied 15 years, 5 months ago 4 Members · 3 Replies
  • Stephen Smith
    March 8, 2011 at 5:49 pm
    There are many ways to do it. One would be to create a black solid and multiple mask shapes and move around to taste. Then you can place your clips behind the wholes the mask shapes have created. Then if you adjust the size of the clip it will be the same every-time.
    Or you could decrees the scale of the clips and move them around to taste. If you need to you can use the crop tool. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Jeff Greenberg
    March 8, 2011 at 6:29 pm
    put three clips in a stack so each clip starts 2 seconds after the prior one.
    Do the following at a point in the stack where all three clips are visible:
    Scale and crop each down. Move them off the center of the frame.
    By scaling it down, each clip won’t be full screen.
    By cropping, each clip won’t have all of its pixels.
    By repositioning the center, each clip comes up on part of the screen.
    As each shot comes on, it’ll have that ’24’ feel.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Mark Suszko
    March 8, 2011 at 7:47 pm
    Got thirty bucks?
    https://www.digital-heaven.co.uk/dh_box
    Or use their free DH grid program to throw up a grid, then use that to control position and proportioning of your various clips, as a reference standard. Lots of graphic artists base everything on a grid system like this. And if you hate typing numbers and doing math in your head, sliding stuff around and sizing it up to the grid boxes may be simpler for you. Combine the free grid with an understanding of the Rule Of Thirds, and you are on your way.
