Activity Forums VEGAS Pro Split Screen with overlap in center
  • Split Screen with overlap in center
    Posted by Bruce Brent on December 18, 2013 at 2:18 am
    I’m hoping for a way to blend/overlap in the center of two video images/split screen where both show with just a bit of overlap. I want both video clips to feather in the middle. Is this possible?
    If so, please send the scenario of how. Thanks!
    Bruce Brent replied 12 years, 9 months ago 2 Members · 6 Replies
  • John Rofrano
    December 18, 2013 at 2:49 am
    You can follow my tutorial for:
    Creating a Split Screen using a Mask
    and just feather the mask as needed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bruce Brent
    December 18, 2013 at 4:38 pm
    John, thanks your your quick reply with a tutorial. But, that’s not what I’m after. I didn’t mention anything about using a green screen.
    What I do want is to have my project video display two moving images across the screen, side by side but the center overlap so both show/crossfade.
    Do you have a tutorial or scenario for that?
    In fact, anyone, please chime in.
  • John Rofrano
    December 18, 2013 at 8:49 pm
    [Bruce Brent] “What I do want is to have my project video display two moving images across the screen, side by side but the center overlap so both show/crossfade.”
    Sorry you didn’t understand my suggestion. It was to create a mask like the one in my tutorial and feather the edge to create the crossfade. Play around with masks and feathering edges and you’ll see what I mean.
    ~jr
  • Bruce Brent
    December 18, 2013 at 9:38 pm
    John, I’ve done exactly what your tutorial directed, but where the two images overlap (center), that verticle overlap is much lighter. There’s no way (that I can try) that blends the two images to show at the same luminous value.
  • John Rofrano
    December 18, 2013 at 10:51 pm
    Feathering the edges of the mask is not in my tutorial but that’s what you need to do. Give the mask a feathered edge and it will blend better with whatever is under it.
    ~jr
  • Bruce Brent
    December 19, 2013 at 4:34 pm
    John, thank you for further explaining this feature.
    Much appreciated
