Activity Forums Adobe Premiere Pro split screen TV scanlines on one side?
  • split screen TV scanlines on one side?
    Posted by Philip James on September 4, 2014 at 1:23 pm
    Further to Ann Bens method of creating TV Scan lines, does anyone know how to create that on only one half of a split screen as in this clip?
    I’ve created a clip on 2 separate tracks and placed the scanline transparency on another track above. I was hoping to be able to switch of the effect on one side but the transparency doesn’t have any effects controls and therefore affects both sides.
    Andy Edwards replied 12 years ago 2 Members · 3 Replies
  • Andy Edwards
    September 4, 2014 at 3:15 pm
    If it’s the exact same clip and only the effect on one, then use the crop tool and crop half the screen to right or left side. You should then only see half your screen with the effect.
    Andy
  • Philip James
    September 4, 2014 at 3:31 pm
    It’s so easy sometimes but the thought process blocks the logic. Cheers for that!
  • Andy Edwards
    September 4, 2014 at 3:34 pm
    No problem. Happy to help out.
