Activity Forums VEGAS Pro split screen multiple images
  • split screen multiple images
    Posted by Jason Barczewski on July 17, 2009 at 9:08 pm
    I’m looking to edit a scene where I will have the video screen split into 5 equal pieces and have 5 different images of people showing in each piece.
    Are there any tutorials that teach that hear at CC or out on the net somewhere, I’m not finding anything and it’s probably because I don’t know the terminology.
    thanks for any help
    Jason Barczewski replied 17 years, 2 months ago 2 Members · 2 Replies
  • Theo Van laar
    July 17, 2009 at 9:22 pm
    Just place the 5 images on 5 different videotracks on top of each other. Then for each track you go to the trackmotion window, which you will find in the trackheader.
    In the trackmotion window you can set the size, place and movement for each image.
    Once you are in the trackmotion window, it is selfexplaning.
    Make sure you select the LOCK ASPECT RATIO button on top of this window (unless you want to change this).
    If you mess everything up on a track, just right-click on the white field in the trackmotion window and choose RESTORE BOX.
    Theo
  • Jason Barczewski
    July 17, 2009 at 11:32 pm
    thanks Theo
