Split screen in vegas
Posted by Ron Black on April 2, 2008 at 8:18 pmI have figured out how to crop a video image, but now need some help in making the image smaller so there is a split screen. How do I do that?
Hardeep Gill replied 17 years, 8 months ago 6 Members · 6 Replies -
Don Bloom
April 3, 2008 at 2:17 amEdward has a tutorial about split screening but I can’t remember off the top of my head which issue of his newsletter it is. Short course, you can use either P/C or Track Motion to resize and move the image to the left or right, then do the same with the other footage. Of course, you need 2 video tracks to do it. I mark one track LEFT and one RIGHT OR TOP and BOTTOM or whatever I’m doing with the footage. Helps keep me for doing silly things if I need to make any change.
That should get you started. OOPPS before I forget, you might want to turn off HOLD ASPECT RATIO (you might need to)
Don
Douglas Spotted eagle
April 3, 2008 at 2:24 amthere are several examples and tutorials for split screen found at:
https://www.vasst.com/search.aspx?g=1&text=Split%20screenSplit screens can be accomplished so many ways…it’s one of the most flexible functions of Vegas, between Track Motion, pan/crop, masking…
Douglas Spotted Eagle
VASSTCertified Sony Vegas Trainer
Aerial Camera/Instructor -
Ron Black
April 3, 2008 at 2:28 amThank you for the feedback. The concern I have, however, is that when you use track/motion, the whole track is changed, not just a single clip in that track. Does that make sense?
Mike Kujbida
April 3, 2008 at 3:49 amDoes that make sense?
Sure does 🙂
It’s called Track Motion because whatever you do affects everything on that track.
You can use keyframes to get around this buy that’s another topic all on it’s own.
The simplest solution is to place each clip on it’s own track and apply the desired FX to it.
Vegas has virtually unlimited tracks so you can get away with doing this very easily. -
Paul Fitzgerald
June 14, 2008 at 8:53 ami have vegas movie studio platinum 8 and i cannot figure out how to split the screen into more than 3 windows because then there are no more video tracks or video overlays. I know how to play with track motion and keyframes a bit. pip scripts cannot be imported into this version. any help would be greatly appreciated. i would love to be able to make a brady bunch type scene. thank you .
Research Center for Wireless Technology
Paul Sean Fitzgerald
https://www.emfnews.org -
Hardeep Gill
December 18, 2008 at 1:06 amHey guys, Im having the same problem. I have a video and i only want a certain portion of the it to have the split screen effect. The track motion just doesnt work out for me since it does the whole video. I cant really get the crop/pan to work for me either.Anyone have any ideas soultions? Any help would be greatly appreciated. And oh by the way Im using sony vegas studio 9a.
