Activity › Forums › DaVinci Resolve › split screen in resolve 8?
  • Margus Voll
    June 30, 2011 at 10:45 am
    you can import stills and then use wipe to compare.
    Or in your case make still from previous shot. R mouse click and make still.
    Then go to next shot. Make still active and press apple w and you should have wipe enabled.
    Hope this helps.
    Margus
    https://iconstudios.eu
  • Danny Scotting
    July 5, 2011 at 1:33 am
    Or, if you need to see the images moving. Use the playheads function.
    Select the clip you are on and then the shot before or after (or both) hit loop and then you can see the shots playing side by side. Can add up to 4 so your screen is quad split and will play all.
    Danny Scotting
    Post Op Group
    Senior Colourist/Grader
  • Sascha Haber
    July 5, 2011 at 7:54 am
    Well, I agree, a moving comparison through the still gallery would be great.
    So everything as it its now, just the clips playing back.
    You could even make it really smart so it starts playback from the frame you are on the master timeline.
    And if the little gallery thing had a slider, you could adjust its position in time there.
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    MacPro 5.1 2x 2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
