Activity Forums Apple Final Cut Pro Legacy Split Screen in Final cut pro
  • Split Screen in Final cut pro
    Posted by Roberto Lopez on December 31, 2008 at 4:03 pm
    >https://www.crashthesuperbowl.com/#/gallery/video/2229/
    I recently worked on a 30 second commercial with a serious deadline. The director wanted a few split screen in the commercial in order to make all the content fit into 30 seconds. I post on creative cow for help but no one really got back to answer the question. So I wanted to post this up to help someone else that might have to do the split screen. The project was very effects heavy with lots of after effects work. I was originally going to do it in after effects. After working on it for a bit I found it time consuming endeavor in after effects. After seeing how much time I was spending on doing this split screen. I jumped on the net to see if I could find a plugin that could do this a bit faster for me. After reading a few articles about DH Box and finding out it was only $20, I quickly purchased the plug in and downloaded it. One of the first things I liked about the plugin was that it worked in final cut pro. Witch was great as I could use the real time playback and it was very simple to use. I did watch the online tutorial that they offer and I was up and running in about 10 minutes. Within half hour I had a few versions to show the director, he was quite happy with the results. I was happy that I was able to make this happen very quickly once I started using the DH box plug in. If you’re interested you can see the project at:
    Omar Estrada replied 17 years, 4 months ago 4 Members · 4 Replies
  • Ben Holmes
    December 31, 2008 at 7:26 pm
    Hi Roberto
    Nice way to get the view count up…
    The commercial has a number of ‘effects’ shots, but the split screen effects you were after can be quite easily keyframed in FCP – you only have to set the start and end point.
    However – I’m a big fan of digital heaven’s products, and I’ll be having a look at DH_box a little closer, so thanks for the reminder…
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Kevin Monahan
    January 2, 2009 at 5:38 am
    DH Box. Probably the first plug you should buy from DH. Eventually, you’ll want them all.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Roberto Lopez
    January 4, 2009 at 8:31 pm
    Dear Ben,
    I agree that the split screen could have been done in fcp with a few key frames, but I found it a bit time consuming when I went to add borders and crop the image and if i wanted to try it out with different clips. I had to start over every time. Plus originally I was going to do it with white borders so it looked more like a comic book. After trying out a few different looks I went with black borders. To tell the truth the borders that I wanted was the biggest problem. I could not find an easy way to do it. So when I found DH_Box pulgin it added borders to my split screen. I think I saved a lot of time because of it. Yes your probably correct you can do it all in fcp with out the plugin but I could not figure out an easy way to do it.
    Ben I want to thank you for taking the time to look it over and for your comments. As you know when you do these kinda projects a few extra hits never hurts.
    Roberto
  • Omar Estrada
    May 2, 2009 at 1:59 pm
    Wow of a commertial!
    I liked your Doritos movie…
    I´m commenting a long time after the date of this post but boy, me salvaste la vida con esta solución…
    Right now I´m facing exactly the same problem: time consuming several splits VS deadline. Will check the DH-Box.
    Gracias
