Activity Forums Apple Final Cut Pro Legacy Split-screen in FCP for phone conversation
  • Split-screen in FCP for phone conversation
    Posted by Arthur Luhn on April 9, 2007 at 3:36 pm
    Hello,
    Is there a good tutorial somewhere that explains how to manufacture a split-screen telephone conversation on FCP? That is, a screen that actively halves in midshot, morphing from one screen into two screen, while the timeline is still in motion.
    Also would like to do a three-way phone conversation.. is this asking for trouble?
    Many thanks,
    FCP 5.1.4
    OS X 10.4.8
    G5 2.66 GhHz Dual-core Intel Xeon
    Panasonic AJ-PCD20
    HVX-200
    1 TB Lacie
    MBE v.2
    Arthur Luhn replied 19 years, 5 months ago 2 Members · 4 Replies
  • Tom Meegan
    April 9, 2007 at 11:04 pm
    Layer the clips on top of one another.
    Double click the clips to load them in the Viewer.
    Click the Motion tab in the Viewer.
    Animate the crop and center properties in the motion tab to hide, reveal and move the clips around for dramatic effect.
    It will make your life easier if you make the Viewer window large for this work.
    Also, with the Viewer window active, hit Command + to zoom into your keyframes.
    The manual does a good job explaining keyframing of Motion parameters.
    Good Luck.
    Tom
  • Arthur Luhn
    April 10, 2007 at 5:47 pm
    Many thanks..
    Does this also cover active morphing? I.e., while the timeline is in motion, we see the original frame with a caller, and then there’s another frame (with the other caller) that enroaches, from the right, sort of pushing the original frame into a cropped position on the left side?
  • Tom Meegan
    April 11, 2007 at 11:46 am
    Keyframe the shots individually, but match their motion so you get the effect you are striving for.
    So…
    Slide the original shot to the right with the center parameter.
    Place the second shot on layer 2 and off to the left
  • Arthur Luhn
    April 11, 2007 at 2:23 pm
    Tom,
    Thanks very much for the reference. I appreciate it. I’ve purchased the book online.
