Activity Forums Avid Media Composer Split Screen Effect
  • Chaz Shukat
    July 2, 2006 at 5:41 pm
    Probably the most common way to achieve a split screen is to use the picture-in-picture effect. On you project window, click the 3rd tab (the one that has a purple icon on it). That’s the effects tab. Select the first group of effects called Blend, the select picture-in-picture. Drag that onto each of you video levels and adjust them to the size, shape, whatever, you want.
    Chaz S.
