split screen
Posted by John Scott on April 8, 2010 at 8:41 amI have an excellent video spoiled by catching the heads of spectators in the bottom quarter of the screen i.e. the whole screen left to right.
Is there a way I can remove that bottom quarter so that I end up with a video without the heads showing ?
many thanks
JohnBill Hames replied 16 years, 5 months ago 3 Members · 7 Replies -
John Rofrano
April 8, 2010 at 10:53 amYou could use Pan/Crop on the Event to crop them out. The default behavior for Pan/Crop is to Stretch to fill frame. You must turn this OFF in the properties under Source. Then anything you crop will just be cut off. If you hold Ctrl+Alt while you drag, it will override Lock Aspect and Size About Center which you don’t want in this case. (you could always disable those manually as well)
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Bill Hames
April 8, 2010 at 2:29 pmGreat tip, John. Now can you move the underlying picture WITHOUT using Track Motion or is my cropped face, for example, always going to be in the same position onscreen? I know this can be done with Track Motion, but that requires a seperate track for each element.
John Rofrano
April 8, 2010 at 5:12 pmYes you can move the picture without track motion. Just move the crop area and it will move the picture.
~jr
Bill Hames
April 8, 2010 at 5:25 pmHmmm.. When I move the crop area the picure element remains stationary. This is something I’d love to do. Been making “slideshows” in Vegas forever. Would like to position 2 pics side by side w/out Track Motion.
Still tryin’. -
John Rofrano
April 8, 2010 at 5:50 pmWould like to position 2 pics side by side w/out Track Motion. Still tryin’.
Follow my tutorial: Creating a Split Screen using a Mask and it will show you how with just Pan/Crop.
~jr
