Activity › Forums › Apple Final Cut Pro Legacy › split screen
split screen
Posted by Eileen Cowin on January 14, 2009 at 1:04 amI want to do a split screen so it fills almost the whole frame. I usually shoot 4:3 and when I edit I scale the image down to about 43%. The images look too small. Any hints?
EileenDavid Roth weiss replied 17 years, 8 months ago 2 Members · 5 Replies -
David Roth weiss
January 14, 2009 at 1:23 amInstead of scaling, you might try cropping unnecessary parts of the image instead. Does that make sense?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Eileen Cowin
January 14, 2009 at 1:35 amThen I really have to plan it out when I shoot. Yes? Maybe make a template for the camera.
Would you still shoot 4:3 or 16:9 (my camera has something called “squeeze mode”)
Eileen -
David Roth weiss
January 14, 2009 at 2:35 am[Eileen Cowin] “Then I really have to plan it out when I shoot. Yes?”
That certainly never hurts… I’ve just always found that anytime i even think about doing splits, it always turns out that cropping works better, because everyone and everything stay larger, and you can still reposition them anywhere in the frame for composition and effect.
[Eileen Cowin] “Would you still shoot 4:3 or 16:9”
Well, shooting 16×9 will give you more leeway when whittling down your splits. It’s almost, but not not quite like shooting HD for a an SD delivery, which allows you to zoom in on on people and objects to 300% because the the HD frame is so much bigger. Of course SD 16×9 doesn’t have nearly that much extra size.
David Roth Weiss
Director/Editor
Eileen Cowin
January 17, 2009 at 5:58 pmHi David,
I wanted you to know that it looks like it is going to work. I shot vertically in squeeze mode on my DVX100. After I did the cropping, I copied back to tape. With the tape back in the camera, I then made a mask with acetate to put in front of the screen.
Thanks so much for your help!!
Eileen -
David Roth weiss
January 17, 2009 at 8:36 pmVery creative workflow Eileen, and I’m glad to help whenever I can.
You really should write an article for the Cow on your technique, and include some pix. I’m sure others would dig it.
Keep it up…
David
David Roth Weiss
Director/Editor
