Activity Forums VEGAS Pro Split project
  • Split project
    Posted by Dirk Wellekens on October 19, 2010 at 8:50 pm
    I am trying to render my first Vegas project, but keep getting the message “low on memory…” I already adapted the page file size, but this doesn’t help. When I delete most of my clips, keeping lets say 5 minutes of the project, rendering seems to works.How can I render small parts of my project and put these rendered files back together if my final purpose is a BD iso-file? What should I render the partial files into? Or how should I proceed? I guess just splitting up the project in small projects and then assemble again into 1 project with file nesting will not solve the problem?
    Dirk Wellekens replied 15 years, 11 months ago 2 Members · 3 Replies
  • Theo Van laar
    October 19, 2010 at 10:45 pm
    Are you working with Vegas Pro 9? If yes, are you using the latest version (9e)? If not, your problem might be solved by updating to 9e
    Theo
  • Dirk Wellekens
    October 20, 2010 at 4:43 am
    The version is indeed Vegas Pro 9e.
    Dirk
  • Dirk Wellekens
    October 20, 2010 at 6:10 am
    Ok, let me put it this way. I’ve seen many posts about the “low memory”, a lot of them without solution. Splitting up the project seems to work in most cases.
    So, if I split up my project in several .veg files and I render each of these small projects, what should I render them into if my final goal is a BD iso-file?
    1) AVCHD, which includes audio and video (I think)
    2) render video and audio separately (blu-ray for video and ac3 for audio) and put them back on the timeline?
    When I put these rendered files on the timeline in a new project and render this “compiled” project, will there be another encoding with possible loss of quality?
    Dirk
