Activity Forums Apple Final Cut Pro Legacy Split long clip into two shorter FILES for DVD burn
  • Split long clip into two shorter FILES for DVD burn
    Posted by Chuckfaz on February 5, 2007 at 1:29 am
    I diged a 40 minute clip that I now need to burn to a DVD. The file is obviously too large for a DVD so is there a way to split the clip into two smaller files. Is this what the Media manager is good for?
    Best,
    Chuck
    Charles Fazio
    Managing Partner
    Mark Rivera’s NewYork State of Mind Entertainment Group (NYSOM-EG)
    Entertainment
    Nick Meyers replied 19 years, 7 months ago 3 Members · 3 Replies
  • Nick Meyers
    February 5, 2007 at 2:20 am
    actually, Media Manager wouldn’t be good for this.
    best would, be to make the one clip into 2 in FCP,
    (create subclips)
    then BATCH EXPORT them.
    the problem with Media Manager is that if the clips but up against each other, & have continuous code,
    then MM will try to be as ecomnimical as possible with hte number of files it creates
    and will not separate them.
    cheers,
    nick
  • Bret Williams
    February 5, 2007 at 6:15 am
    Just open the clip in Quicktime, make an in and out and copy and paste that to a new QT movie, then make an in and an out and paste second half to a qT movie.
    No exporting, rendering or any of all that. Don’t even have to open FCP.
  • Nick Meyers
    February 5, 2007 at 6:40 am
    that will only create a reference file.
    it wont be able to be backed up to DVD, which is the goal.
    you could do it in quicktime,
    but as well as going thru the steps you’ve outlined you would have to do a save as, and make it self contained.
    i’m not sure you would keep the timecode, either, although it’s worth testing.
    you;d have a hard time with frame accuracy,
    but as long as there was enough overlap it wouldn’t matter.
    nick
