Activity Forums Adobe After Effects Split Flap Display (old style departure board)
  • Split Flap Display (old style departure board)
    Posted by Tim West on August 17, 2015 at 9:29 am
    I’m looking to create a ‘split flap display’ rig in AE (similar to the old style departure boards which flip through various ‘cards’ to create numbers & letters).
    The rig ultimately needs to consist of a grid of ‘units’ (top & bottom flaps) which can transition between images covering the entire grid – through to individual images on each unit.
    Ideally I would be able to customise the transitions too – for example a ‘cascade’ of flipping diagonally across the board, or a in a radial motion outwards from the centre.
    This link illustrates the effect I’m looking to achieve: https://vimeo.com/101380658
    I’ve done a bit of research & have found various tutorials which go some way to achieving have reached a bit of a dead end in terms of creating large single images with variety of transitions.
    If anyone has any experience of creating something similar or knows of any techniques / plug-ins that might be useful, I’d love to hear from you.
    Thanks for your time,
    Tim
    Tim West replied 11 years ago 2 Members · 2 Replies
  • Cassius Marques
    August 17, 2015 at 1:13 pm
    I don’t think AE is ideal in doing this sort of thing. You need a lot of masking, the front and back start to overlap…Its a hassle!
    I mean, a split flap display that transitions between two images if fine.
    On the other hand, a rigged one, that can hold several size images and have its transition chosen and that works in 3d is a little bit too much. You would have to do A LOT of pre comping and your largest resolution image comp must be inside every possible combination of a flip side.
    I remember doing not even half you what you’re going for and it was painfully slow for AE to handle.
    My advise would be: go to a 3d application if you can. Avoid the overlapping and the pain of getting good shadows and the motion blur issues and the huge layer nesting.
  • Tim West
    August 17, 2015 at 1:38 pm
    Thanks for the reply – I’m gradually coming to the same conclusion!
    Unless there is a way of ‘faking’ the effect using a looping animation to simulate the cards flipping through until they settle on an image, I think a 3D application (am thinking C4D) will be the way to go too.
    Thanks for your input anyway! 🙂
