Activity Forums Maxon Cinema 4D Split Flap Display (Departure Board) Rig – Mograph?
  • Split Flap Display (Departure Board) Rig – Mograph?
    Posted by Tim West on August 17, 2015 at 1:45 pm
    I’m looking to create a Split Flap Display rig in C4D (similar to the old style departure boards in airports / train stations with flipping cards which create numbers & letters).
    The rig ultimately needs to consist of a grid of ‘units’ (top & bottom flaps) which can transition between images covering the entire grid – through to individual images on each unit.
    Ideally I would be able to customise the transitions too – for example a ‘cascade’ of flipping diagonally across the board, or a in a radial motion outwards from the centre.
    Here is an example of the effect I am looking to achieve:
    https://vimeo.com/101380658
    I’ve started to research this & figure that some kind of Mograph based rig might hold the solution – see below for my *very* basic attempt – planes in a radial cloner which are held in position by plain effectors – the cloner then being rotated to create the flipping motion (thanks to Base80 for the idea!).
    I fully appreciate this is a difficult effect to create as I have described, but any assistance or ideas on how to achieve this would be great.
    Thanks for your time,
    Tim
    Tim West replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
