Activity Forums Adobe After Effects Split Field Render Times
  • Split Field Render Times
    Posted by Matt Wafaie on July 14, 2006 at 4:40 pm
    If you render something with split fields, would it stand to reason it would take around twice as long to render than if fields were turned off because of AE’s upper, lower, render cycle?
    Matt Wafaie replied 20 years, 1 month ago 9,530 Members · 1 Reply
  • Matt Wafaie
    July 14, 2006 at 5:22 pm
    Oh I understand all of that fully. I just ask because I had rendered a project without interlacing which took 8 hours. I rendered it again last night with interlacing settings corrected and at 12 hours it was only about 3/4 of the way done. I thought, either this machine is dying or there’s an extra process happening here. I just wanted to see if my suspicion was correct.
    Thanks.
    M@
