Activity Forums Adobe After Effects Expressions Split() expression with If else
  • Split() expression with If else
    Posted by Mac Lad on May 21, 2021 at 2:37 am
    hello guys,
    I have a text layer with below given expression on sourceText property which tries to grab names from the comp which has list of 208 countries name in it. Every country is a precomp and has a respective code and county name on it eg. IND – INDIA.
    id = thisComp.layer("CONTROL").effect("SELECT COUNTRY")("Menu");
    c = comp("Country Names").layer(id).name.split("-")[1];
    but my problem starts where the country name like USA are written which only has code in name due to character limitation in design. So I am trying to write an if/else statement which can check based on “-” in name. So names without “-” will be used as written on precomp. I came up with below expression but this won’t work as expected.
    c = comp("Country Names").layer(id).name;
    if(c.split("-")>0){c.split("-")[1]} else {c};
    Thank you!
    이 중광 replied 5 years, 4 months ago 3 Members · 3 Replies
  • Dan Ebberts
    May 21, 2021 at 3:07 am
    Try adding .length to the split array, like this:
    if(c.split("-").length>1){c.split("-")[1]} else {c};
  • Mac Lad
    May 21, 2021 at 3:25 am
    Thanks Dan, that works!!! Didn’t knew I can use .length in split …thanks!!!
  • 이 중광 Create COW Profile Image
    이 중광
    May 21, 2021 at 3:58 am
    if (c.split("-")[1] == null) {c} else {c.split("-")[1]};
