Activity Forums Apple Final Cut Pro Legacy Split end edit
  • Posted by Jay Goldstein on February 25, 2006 at 10:57 pm
    I know there is a simple answer to perform a split end edit ( also a L edit) where the audio begins under the previus picture before you cut to the current picture, but I will be damed if I can find it as described in the Apple manuals..slip? Slide? Trim? ..and the audio should keep in sync. I have FCP 4.5 and have been on this for over an hour..tx
    Tom Wolsky replied 20 years, 6 months ago 3 Members · 3 Replies
  • David Battistella
    February 26, 2006 at 4:24 pm
    It’s the option or control key and just drg the track(s).
    David
    Peace and Love 🙂
  • Jay Goldstein
    February 27, 2006 at 2:40 am
    thanks, but it still does not work properly..the video and audio go out of sync, LINK is off, I tried using Slip and Slide and the book is not forhtcoming in the HOW to do this audio split..any other suggestions? thanks again
  • Tom Wolsky
    February 27, 2006 at 12:44 pm
    If you unlink and use slip or side you” move the audio out of sync. Leave linked selected turned on. Press the Option key and in the Timeline grab the end of the audio edit. With the Option key drag it left or right to change the audio In point. If there is another clip abutted to it, use the Roll tool (R).
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
