Activity › Forums › Adobe After Effects › Split composition into separate render items at exact frame end
  • Split composition into separate render items at exact frame end
    Posted by Mariela Sepulveda on September 19, 2016 at 10:58 am
    Good morning! I split an after composition in 2 parts. Rendered them separately (mov) and the tried to concatenate them using FFMPEG. It works well except for a 1-second stop (bith audio and video) at the joint. The only difference between both parts is the bitrate: a. Part1e: 22391 kb/s and Part 2: 22220 kb/s. After many tests, I believe (i may be completely wrong!) that my problem is how i split the composition in After. I did it at any random sec. Not sure if this is right, but if there are FRAMES in the comp, I may need to do the cut at the exact place where a frame ends and another starts. Does this make sense? My feeling is that since I am not cutting it at that exact place, when i render both parts, it is completeing the last frame or something… so when I merge both files, it is completing what is missing of the frame with a still image and silent sound. Sorry if I am way off….
    Thanks for your help.
    Mary
    mariela.sepulveda@gmail.com
    Daniel Waldron replied 10 years ago 2 Members · 2 Replies
  • Mariela Sepulveda
    September 19, 2016 at 5:39 pm
    Hi Dave. Thanks a lot for your fast response.
    The reason I am doing this is because a part of the video (part1) has variable data that I need to update in order to generate several personalized videos. And part 2 remains the same for all videos. So I just want to render part 1 several times and concatenate part 2 without rendering this second part.
    Hope it makes sense.
    Thanks a lot!
  • Daniel Waldron
    September 19, 2016 at 8:07 pm
    There are frames in every After Effects composition, so that’s not your problem. Your issue is either (A.) there are black frames after you made a cut in the first section (B.) there are black frames at the beginning of your second section or (C.) the software you are using is inserting a space between the two clips.
    I would check each clip individually, and if both look clean and you still have issues, I would take Dave’s suggestion and bring them into Premiere (Or even AE again) to combine. Then you can see how it plays back and adjust anything if needed.
