Activity Forums Adobe After Effects Split Color Channels for Mattes
  • Todd Kopriva
    May 15, 2010 at 5:27 am
    Check out the Channel effects.
    A simple one for using the color channel values as alpha channel values is the Set Channels effect.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Chris Wright
    May 15, 2010 at 5:41 am
  • Jason Mckee
    May 15, 2010 at 8:43 am
    Okay cool. I was doing it right. I just had to be sure. Also the shot I was testing it on wasn’t very ideal since it had no clear difference between the channels. Thanks.
