Activity › Forums › Apple Final Cut Pro Legacy › Split Channel Animation
  • Split Channel Animation
    Posted by Girshon Rutstein on July 9, 2009 at 4:03 am
    3-4 years ago I created a logo (png) by separating RGB and moving from 2 directions into one final color logo. The client changed the logo and I lost the original project and my memory as well. I might have used a plugin (Boris Continuum) or what not, but I am sitting here for a hours and trying to figure out how I did it. It drives me nuts that I can’t recall my own project. To create this took me 10 sec.
    Here is the original file https://www.dreamimages.net/test.html
    I would appreciate some help.
    Girshon Rutstein replied 17 years, 2 months ago 2 Members · 2 Replies
  • David Bogie
    July 9, 2009 at 3:09 pm
    I don’t see that you split the single layer into RGB at all. Looks like three copies of the layer, set one channel of each layer.
    But if you get a solutionhere at the cow, please have the courtesy to return to apple.com and let those guys who worked for you for several hours to help you out know what you received here.
    bogiesan
  • Girshon Rutstein
    July 9, 2009 at 4:11 pm
    I always do.
    I did find the solution. The effect is called BCC Missalignment. You can split RGB and animate them using key frames.
