Activity Forums VEGAS Pro split between frames.
  • split between frames.
    Posted by Doyal Gudgel on September 23, 2012 at 6:24 pm
    At the moment I only know how to split an event on a frame. How can I split an event between frames so I can save both frames? Thanks
    Doyal Gudgel replied 13 years, 12 months ago 2 Members · 9 Replies
  • 9 Replies
  • Mike Kujbida
    September 23, 2012 at 11:45 pm
    If you mean splitting an individual frame, that’s something you never ever do as it will mess things up horribly.
    You always split on frame boundaries only.
  • Doyal Gudgel
    September 24, 2012 at 2:00 am
    That’s right. In the timeline the way mine is set up I can expand the timeline until I have the option of selecting one frame or the other to split. It is expanded down to individual frames but selecting one or the other to split may still leave that frame in the other event as a complete frame. . There is no way to split between the frames. I don’t get the option to split between the frames leaving the left frame on the left event and the other frame on the other side of the split in the new event. . There must be another way to set it up to leave one frame in the previous event and the frame on the right side in the other event. In film you cut the film between frames then join the new scene at the cut. Hope this is understandable.
  • Doyal Gudgel
    September 24, 2012 at 2:37 am
  • Mike Kujbida
    September 24, 2012 at 10:41 am
    I couldn’t follow the link to your blog so I’ll try and explain it to you.
    “…selecting one or the other to split may still leave that frame in the other event as a complete frame.”
    That’s the way things are supposed to work.
    “There is no way to split between the frames.”
    A video edit is an electronic edit and MUST be done on the frame boundary.
    “There must be another way to set it up to leave one frame in the previous event and the frame on the right side in the other event.”
    You have an event with frames 1, 2, 3, 4, 5 and 6.
    You want to split it at frame 4 so you place your cursor at the end of frame 3 and press the ‘s’ key to split it.
    The first new event consist of frames 1, 2, and 3.
    The second one consists of frames 4, 5 and 6.
    It’s as simple as that.
    If you decide that you don’t want frames 3 or 4, do another split and delete it.
    “In film you cut the film between frames then join the new scene at the cut. Hope this is understandable.”
    You can’t/don’t edit video like you do film (physically cutting it) so stop thinking you can.
  • Doyal Gudgel
    September 24, 2012 at 4:19 pm
    That explains it Simple enough I was confused about the effect of where the cursor was put. Now another question as long as I have your attention. I have duplicate pictures in the timeline which usually I don’t want there. In the project media panel there is media noted as “copy” Does Vegas say “copy” when a duplicate copy of media is imported from a different folder on the computer than the earlier copy came from? Or is it that I just copied the media twice to the timeline? Knowing which will help a lot
    Thanks.
  • Mike Kujbida
    September 25, 2012 at 10:17 am
    “Does Vegas say “copy” when a duplicate copy of media is imported from a different folder on the computer than the earlier copy came from? Or is it that I just copied the media twice to the timeline? Knowing which will help a lot”
    I use Vegas Pro so I’m not sure. A browse of the manual or the online help menu should explain things.
  • Doyal Gudgel
    September 25, 2012 at 2:27 pm
    I usually check help for an answer but this question had no answer. I did find out anyway. Copy’s are the result of importing the same picture twice At least in this instance. I have a huge number of duplicate photos. What I need is another “good” duplicate file finder.
  • Mike Kujbida
    September 25, 2012 at 7:19 pm
    The only way to have an image in there more than once is if you put it there. Maybe you had a reason for doing this?
    If Movie Studio works the same way Vegas Pro does, change the view in your Project Media tab to “Details” and look in the “Use” column.
    If you click on it, it will sort from low to high or high to low.
    Anything with “2” or more is probably a duplicate event.
    In the screenshot below, there are a number of instances of various events and this is because it was a few long ones that were split up as needed.
  • Doyal Gudgel
    September 26, 2012 at 2:49 am
    There seems to be the same information in my version. Expanding my version shows lots of other columns and lots of other information. In this picture maybe you can see the one jpg that has the number 2 with it. I suppose it was used two times. I had already removed all the copies so I don’t know how they would have looked. But taking out a bunch didn’t change the length of the project so they were not brought into the timeline is the way I read it. But with this information I can soon find out.
    I can find an event in project media from the timeline but can i find the media in the timeline from project media?
