Activity Forums Adobe Premiere Pro Split a stereo track into 2 mono tracks
  • Split a stereo track into 2 mono tracks
    Posted by Sean Kimbell on June 6, 2009 at 5:57 pm
    I am trying to split a stereo track with left and right audio to two mono tracks with the left channel in one track and the right channel in the second track. I have been reading and all I seem to get is select the audio clip and then goto to Clip/Audio Oprions/breakout to mono. Unfortunately the menu item BREAKOUT TO MONO is greyed out and does not let me select it. I also read that you can force all clips to send the tracks to mono tracks on import. This will not work for me in this case I have already created the entire production and now I need to remove the channels that have ambient sound on them and just keep the tracks that represent the mics that I used on the set that day. I hope this makes since and someone can help me with this.
    Sean Kimbell
    Sadia Ad replied 11 years, 8 months ago 8 Members · 7 Replies
  • 7 Replies
  • Eddie Lotter
    June 7, 2009 at 4:47 pm
    I suspect you are trying to work on the timeline. You need to use breakout to mono on a clip in the Project Panel.
    See: FAQ:How do I create mono/stereo out of stereo/mono audio?
    Cheers
    Eddie
  • Jeff Pulera
    June 9, 2009 at 7:58 pm
    Hi Sean,
    I’ve always just used “Fill Left” and “Fill Right” audio filters dropped onto the audio clip. I’ve had footage with ambient on left channel and wireless on right, I just add FILL RIGHT and then have wireless sound only on BOTH channels
    Jeff Pulera
    Safe Harbor Computers
  • Jim Wilkinson-ray
    June 16, 2009 at 4:57 pm
    Thank you – thank you – thank you!!!!
    Wanting just oneone channel of a stereo field to be placed in the center of the master output is so common – I can’t believe it was so hard to find this answer and is so suttle within P Pro.
    I spent a disgusting amount of time trying to read through Adobe’s help files, calling them and searching the web for what used to be a simple operation on my old editing software.
    I had tried fill left & right, but didn’t realize that it was “pre-fade”, so I didn’t hear a change.
    Thanks again!
    Corp. Communications & PR
  • Michael Cooper
    November 10, 2011 at 9:07 am
    Hi I was wondering if someone could explain to me how to split the stereo audio on import. I use a lavaliere mic connected to my GH2 audio in and so all the audio I record on the camera is just one channel on a stereo recording. I want to simplify my workflow and be able to make 2 mono tracks and delete the empty track and duplicate and pan the good track.
    The “Fill left” “Fill Right” way works great, but just out of curiosity (final cut user style) How do I do it on import the other way?
  • Robert Bracken
    June 5, 2013 at 2:30 pm
  • Adrian Roup
    June 25, 2013 at 5:59 am
    Thank you Jeff!!
  • Sadia Ad
    January 6, 2015 at 3:34 am
    Thanks Eddie!
