Activity Forums Maxon Cinema 4D splines issue
  • splines issue
    Posted by Jason Boos on July 9, 2010 at 6:55 pm
    Ok, so here’s the procedure i’m doing.
    I am recreating a heart: flat top, bottom and sides. Adding a lil extrude to it too.
    I drew oner half of the heart on the XY axis using a linear spline, and applied a symmetry nurb to duplicate.
    My problem is now to get the two to join together. When i drop everything in the extrude nurbs, the extrude occurs occurs as an outline, not filled in.
    Anybody could give any advice as to what I’m doing wrong?
    Jon Bonebrake replied 11 years, 8 months ago 4 Members · 6 Replies
  • Adam Trachtenberg
    July 10, 2010 at 2:34 pm
    Make the symmetry object editable, select the resulting spline, and check the “close spline” box in it’s properties.
  • Jason Boos
    July 10, 2010 at 7:49 pm
    ok i tired that, but i get two lines running down the middle.
    How can i avoid that?
  • Brian Jones
    July 10, 2010 at 9:02 pm
    it sounds like the spline was not quite close enough in the Symmetry Object to join (weld) the two parts. So either make sure it welds in the Symmetry or do it by hand in the editable version
  • Adam Trachtenberg
    July 10, 2010 at 9:23 pm
    Oops, you’re right. Problem is that both segments are running in the same direction, so when you close the joined spline it connects from top to bottom. Solution: before checking the “close spline” box, select two of the overlapping endpoints and run the “join segments” command. That will weld them and set a continuous direction for the spline. Then check the close spline box.
  • Jason Boos
    July 11, 2010 at 4:58 am
    IT WORKED!!!! THANK YOU THANK YOU THANK YOU!!! I HOPE TO GOODNESS MY STUPID BRAIN DON’T FORGET NOW!!!
  • Jon Bonebrake
    January 13, 2015 at 6:17 pm
    Wow… this: “Oops, you’re right. Problem is that both segments are running in the same direction, so when you close the joined spline it connects from top to bottom. Solution: before checking the “close spline” box, select two of the overlapping endpoints and run the “join segments” command. That will weld them and set a continuous direction for the spline. Then check the close spline box.”.
    Helped me. Fixed my problem. Thank you!!!
