Activity Forums Maxon Cinema 4D Splines from Illustrator to C4D
  • Splines from Illustrator to C4D
    Posted by Clay Stanton on April 4, 2011 at 2:44 pm
    Hi I’m trying to export a Spline from AI CS4 to Cinema 4D 11.5
    It’s an open path in Illustrator but when I bring it in, C4D keeps closing the path. Is there something I need to do to keep the path open?
    I’ve tried exporting from Illustrator as EPS and AI. Same results.
    Ronny Traufeller replied 15 years, 5 months ago 2 Members · 1 Reply
  • Ronny Traufeller
    April 4, 2011 at 3:00 pm
    usually i use illutrator 8 as file format.
    try to disable the “close spline” checkbox in the spline parameters.
    hope that works..
    Ronny
    traufeller.de
