Activity Forums Maxon Cinema 4D Spline wrap not in same position as spline
  • Spline wrap not in same position as spline
    Posted by Jack Cook on March 31, 2010 at 3:27 pm
    I’m using Mograph Cloner to clone some arrows, and a SplineWrap object to animate them along a spline. The problem is that the arrows are not where the spline is, but offset from it quite a bit. How do I get the arrows to actually be ON the spline instead of away from it?
    thanks
    Jack
    Jeremy Allen replied 16 years, 5 months ago 2 Members · 3 Replies
  • Jeremy Allen
    March 31, 2010 at 5:36 pm
    I haven’t used Spline Wrap too much, but I know you can get a similar result with the Spline Effector.. Have you tried that?
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6
    C4D 11.5
    AE CS3
    FCP 6.0.1
  • Jack Cook
    March 31, 2010 at 6:01 pm
    Thanks for the suggestion. I just tried it and it works.
    On experimenting further, I found that with the Spline Wrap the spline you use has to be closed. I was using an open linear spline with the spline wrap, and got the offsetting. But when I closed the linear spline, the arrows then were on the spline, but they were going in both directions instead of just one. The spline was a straight line, so this wasn’t what I wanted.
    Using a Spline Effector I could put the arrows on the open linear spline, and animate them, too. Great suggestion!
    Jack
  • Jeremy Allen
    March 31, 2010 at 6:18 pm
    Hey glad I could help. And thanks for following up with the results of your experimentation.
    C4D 11.5
    AE CS3
    FCP 6.0.1
