Activity Forums Maxon Cinema 4D Spline Wrap and compositing tag
  • Spline Wrap and compositing tag
    Posted by Gon Perdigao on April 17, 2009 at 11:51 am
    Hithere i have a spline wrap and i want to export the animation to after effects, but when i put a compositing tag, i have a still null, not with the movement that i made, how can i export the animation of the spline wrap to after effects?
    Here is the project https://www.sendspace.com/file/q20ej1
    Thanks a lot
    Josh Johnson replied 17 years, 4 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    April 17, 2009 at 2:37 pm
    You’ll have use a little Xpresso to get the coordinates of the points that are being deformed by the spline wrap object. Here’s an example: https://www.3danvil.com/tutorials/spline_wrap_AMT.c4d
    What this does is get the position of the deformed point, attaches a null to that point, and assigns the external compositing tag to that null.
    I chose a point on the leading edge of the cube, but you can pick any point you want by opening the xpresso editor, clicking on the point node, and entering a different point index number.
    To figure out the index number of a point, go into points mode, select the point, and look in the structure mananager (set to points mode) for the point that’s highlighted.
  • Gon Perdigao
    April 17, 2009 at 10:04 pm
    but i want to do is, parent an object in after effects to the point of spline wrap.
    How can i do that?
  • Adam Trachtenberg
    April 18, 2009 at 4:15 am
    Um, parent it to the null with the external compositing tag.
  • Josh Johnson
    May 15, 2009 at 7:23 pm
    This is GREAT! THANKS!
    SPLINE WRAP to AFTER EFFECTS solution!
    yay!
