Activity Forums Maxon Cinema 4D spline with random movement
  • spline with random movement
    Posted by Stephen Grimm on March 17, 2011 at 5:22 am
    This may be a simple answer, but I’m new to C4D.
    I’m growing along a spline with sweep nurbs. How would I go about giving each of the points in the spline a random movement. Sort of like a waving tentacle.
    I’ve tried messing around with the vibrate tag with no avail.
    Thank you.
    Adam Trachtenberg replied 15 years, 6 months ago 4 Members · 5 Replies
  • Randy Johnson
    March 17, 2011 at 7:13 am
    Try the Formula deformer as a child of the spline. Or maybe the wind deformer.
    /Randy
  • Emmet Reddy
    March 17, 2011 at 10:15 am
    You could also try point level animation and animate some of the points on the spline?
  • Adam Trachtenberg
    March 17, 2011 at 1:13 pm
    Another option would be to use a MoGraph random effector in deformer mode, with the effector mode set to noise or turbulence.
  • Stephen Grimm
    March 17, 2011 at 2:50 pm
    Thanks, those are both working nicely.
    How would I keep the root of the spline from being affected?
  • Adam Trachtenberg
    March 17, 2011 at 5:55 pm
    You can use falloff if you’re using the random effector method.
