Activity Forums Maxon Cinema 4D Spline with multiple separate splines – need to sweep
  • Spline with multiple separate splines – need to sweep
    Posted by Brian Murphy on January 4, 2017 at 6:27 pm
    Hi all,
    I have one object, a spline with several separate splines in it, they are not joined together. I need to animate the growth over time but if I do, one piece of the spline grows, then the next, then the next, etc. I need them all to grow from the first point of each individual spline part…is this possible?
    Thanks.
    Brian
    Adam Trachtenberg replied 9 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 5, 2017 at 5:27 pm
    Use a MoSpline referencing your spline object and set the Grow Mode to Separate Segments.
