Activity Forums Commotion spline motion blur on 1st frame
  • spline motion blur on 1st frame
    Posted by Iishohin on April 19, 2005 at 10:46 am
    hi.
    recently i had to roto a sequence whose 1st frame had some motion blur on it. when i switch the rotospline motion blur on, quite understandably the blur starts on frame 2. ideally i would have liked it to start from the 1st frame.
    So is there any workaround that will for example let me position the spline on a 0th frame so that the 1st frame can have blur applied?
    thanks in advance
    J Bills replied 21 years, 5 months ago 3 Members · 4 Replies
  • J Bills
    April 19, 2005 at 11:56 am
    sure – reexport your clip with a blank frame 0. Motion blur needs that frame before/frame after to work properly, so just feed it another frame.
    Or, you can export the matte and hand paint the blur using the paint tools (either cloning from frame 2 or just blurring by hand).
  • Iishohin
    April 19, 2005 at 5:07 pm
    thanks for the suggestion.
    i knew i could re-export the clip with the extra frame, but i thought that for such a basic but important thing as applying blur on the first frame could be done in a less hard-disk-hungry and simpler fashion. Painting, in the case i am working on would be impractical.
    Does the SilverMan have any thoughts on the matter?
  • Matt Silverman
    April 21, 2005 at 4:49 am
    [J Bills] “sure – reexport your clip with a blank frame 0. Motion blur needs that frame before/frame after to work properly, so just feed it another frame.
    Or, you can export the matte and hand paint the blur using the paint tools (either cloning from frame 2 or just blurring by hand).”
  • J Bills
    April 21, 2005 at 11:49 am
    ha!
    you might also try adding a keyframed directional blur on the matte render, that is only present on frame one and then keyframed to “off” on frame 2. That might be a good cheat.
