SPLINE MODEL
is it possible to create a flat dohnut using splines? Maybe a ring would be a better example
Basically im trying to create an outer and inner spline. The outer being the solid and inner being void so when extruding only the outer ring rises and not the inner.
Im trying to apply this theory to a pavement around a road and want to avoid booleans where possible as they tend to be a bit of a resource drain.
Kind Regards
Bryan Richards
