Activity Forums Maxon Cinema 4D Spline Mask
  • Spline Mask
    Posted by Joe Bodego on July 10, 2016 at 9:03 am
    I am having a hart time doing a spline Mask with a clone object. Here is how i set it up. I created a clone object with about 25 squares. I then created a circle, place both the circle and the clone in the ‘Spline Mask” then selected “A subtract B” and nothing happens. I have to convert the clone to a spline, select all the splines, do a connect and delete then it works. In short can a clone work in a spline mask?
    Joe Bodego replied 10 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 10, 2016 at 1:33 pm
    sure, put the cloner inside a Connect object and use that in the spline mask
  • Joe Bodego
    July 10, 2016 at 7:42 pm
    Thank you so much, this really helps
