Activity Forums Maxon Cinema 4D Spline Mask not working as expected
  • Spline Mask not working as expected
    Posted by Christopher Handrick on June 20, 2012 at 3:24 pm
    Hello,
    I’ve been watching some very cool things being done with the spline mask tool and I wanted to give it a shot myself, but I’ve run into a problem I’m not seeing in any of the tutorials I’ve watched. I created my two spline objects and put them inside the spline mask, and then swithced it to ” A subtract B ” expecting one spline to cut a chunk out of the other, but instead all that happens is one spline will become invisible. I’ve tried moving them around and changing their stacking order but all that does is to change which one is being displayed. Can anyone tell me why the splines aren’t masking as expected?
    Adam Trachtenberg replied 14 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 20, 2012 at 7:50 pm
    Make sure that the splines are 100% on the same plane. Otherwise it doesn’t work.
