Activity Forums Maxon Cinema 4D Spline effector question
  • Spline effector question
    Posted by Craig Whitaker on March 3, 2011 at 9:03 pm
    Hey everyone,
    Two part question here….
    1) Can the Spline Effector follow a user created path to travel between objects?
    2) Is there a method/trick to using a piece of geometry as the goal object, not a spline?
    Thank you,
    Craig
    Craig Whitaker
    MFA Candidate
    New York University
    http://www.craigwhitaker.net
    Ronny Traufeller replied 15 years, 6 months ago 2 Members · 1 Reply
  • Ronny Traufeller
    March 7, 2011 at 12:28 am
    hi!
    1.yes it can, every spline can be used if its a spline. try using
    offset-start-end parameters in the effector moving them towards your objects.
    2. not sure how it would be usefull but, maybe just draw along the geometry, or you could use the cloner in object mode and do something with offset.
    Ronny!
